can i swap 34pict for 30pict???????
https://forums.aussieveedubbers.com/threads/86602/can-i-swap-34pict-for-30pict
k_love ·
hoping someone can help with a troublesome 34pict-3
i want to swap out my untunable 34pict-3 with a
30 pict that has an adapter to suit my manifold
like this
http://www.cbperformance.com/catalog.asp?ProductID=1596
its a stock 1600dp in a bus with vacuum adv dist.
will i face any problems or is it a straight swap?
will there be any tuning or drivability issues?
should i just buy a single weber?
thanks
james
I have used a 30 pict on a 1600 before
Should be a straight swap
matara ·
James,
I have a less than 1 year old Brosol H30/31 with the adapter you are needing, that I would swap for a 34-PICT (I'm going from 1300DP to 1600DP) I would swap if yours is in good condition. How come its not tunable though?
k_love wrote:hoping someone can help with a troublesome 34pict-3
like this
thanks
james
IF YOUR DIZZY IS ONLY VACUUM IT MAY WORK....
BUT IF ITS VACCUM AND MECHANICAL with a small vacuum canister.. therte isn't enough vacuum to work the smaller canister with a pict 30/31
unscrew your mixture screw...
the end may be broken or bent..
