Thinking of selling me EJ22 or a EJ20T but in my ghia its low to the ground and ground clearance is an issue. On a Ej20t would anyone be able to measure from the center of the crank to the topside where the header would mount to the heads? I have a feeling its different from my ej22 because of being a single over head cam.
done it...no difference. only real difference in a bay was i had to modify the engine support crossmember to accomodate the bigger heads😏
Bit more envolved with a bug or ghia rob, they have narrower engine bays than type4 kombis
Richard, the quad cam motors are about 2" wider each side than the twin cams
heres a pic I took of a ghia with an EJ20T at a show which should give you a rough idea
