101.6mm cylinders into Wasser case
https://forums.aussieveedubbers.com/threads/86659/1016mm-cylinders-into-wasser-case
66deluxe ·
I got a 1.9 wasser case that one day will be turned into an oxyboxer and was wondering if the 101.6mm cylinders that are available fit in to the case register without machining?
Cheers Damo.
dangerous ·
nah dude, case hole is only 100mm like type 4, but yes the case can be machined ut just like the others.
Mine used 4.03" = 102.36mm
