34 Pict 4 carby leaking fuel
https://forums.aussieveedubbers.com/threads/86741/34-pict-4-carby-leaking-fuel
super72beetle ·
Hi guys.
I recently bought a second hand 34 pict 4 carby as my 34/3 was leaking air in through the throttle arm.
I cleaned out the 34/4 and popped it on today only to find that fuel is leaking out of the accelerator brass pipe (with the engine off!) Any ideas what this could be?
My feeling would be that the float might need to be adjusted.
I'm struggling to find much info on the 34/4 on this site and the Samba. Also, if anyone has experience with these carby's can they tell me if I can just plug the two extra vacuum ports.
Thanks.
I'm putting this on a stock 1600dp.
greedy53 ·
i had similar and found that the needle and seat was the wrong one to short a fiber washer fixed it also the acc pump diafram mite be holed,pull it part being careful and have a look they are easy to do
good luck
super72beetle ·
Thanks Greedy. I have changed the needle and seat but will go and put an extra fibre washer on.
super72beetle ·
Hey Greedy.
Turned out to be a wrong needle and seat.
I've plugged both vacuum ports and it runs like a dream.
Thanks for the advice.
Simon🙂
