MaD HoUsE ·
is it called tubbing when you make extra room for your whees on full lock cos i just put some new ones on there and they look soo good but at full lock it rubs and makes a hell of a racket. anythin i can do? anyone faced this b4?
https://forums.aussieveedubbers.com/threads/86802/tubbing
MaD HoUsE ·
waveman1500 ·
MaD HoUsE ·
waveman1500 ·
Type 3s have different offsets to Beetles so some aftermarket wheels will rub, but you should be fine with 165s on 5.5" rims. If you can, try and work out where it is actually rubbing, look for wear/rub marks inside the wheel wells. If it is rubbing on the inside you could try some kind of spacer, if they're rubbing on the outside (more likely I think) then you may be able to roll the lips.MaD HoUsE wrote:the wheels are pretty standard which surprised me the 15 by 5and a half with 165's on them not sure wher the rubbing happens but its only at very full lock wich unfortunetly i need to do to get into wrk everyday. it has got slight camber and the offset has changed. it looks reall tough so i dnt wanna loose the wheels
zocstar ·
MaD HoUsE ·
oztype3 ·
