T1 tie rod length ?????
https://forums.aussieveedubbers.com/threads/86841/t1-tie-rod-length
cnfabo ·
howdy,,,,, does anyone know the length of the short tie rod on a k&l beetle "64 model" stock width beam.....
Tie rod or tie rod assembly ???
The tie rod I just measured was 225mm including the jam nuts on one end (clamp style on the other).
For interest, a ball joint one was 190mm that had clamp style on both ends.
cnfabo ·
thanks matt, should be good enough....i hate trying to figure how long to cut them to acheive the right toe adjustment range.....just taken a norrowed beam out to put a stock one in,as i now have 3 degree bent trailing arms....
