fuel delivery pipe
https://forums.aussieveedubbers.com/threads/86869/fuel-delivery-pipe
OLLY ·
would like some ideas on how to make sure the pipe that goes in to the carburettor doesn't make it's way lose.
thinking of tie wire around clamp then around carburettor
thanks
OLLY wrote:would like some ideas on how to make sure the pipe that goes in to the carburettor doesn't make it's way lose.
thanks
or wire clamp to closest screw as on aircraft..
also do the fuel pump...
as they can pop out too....
Some people are now taping the inlet hole and fitting a fuel pipe fitting... so, it can't come out....
I have been doing this for years you can also makea small metal tab with a hole in it to go under one of the carby top cover screws or wrap a piece of tie wire aroun d the carby as you suggest
Also the most important one is to do the fuel pump outlet line as this will and does also fly off under pressure
the problem is you have 2 diffent metals brass and Alluminium so Corrosion can occur between the diferent metals and will cause the pipe to come off and creat a fire
Most people by now have one of the replacement pumps with the 1 piece pressed steel tops so they cant spit the fitting out.
As above the best saftey measure is the old saftey wire on the carb and old style pumps
OLLY ·
Hi thanks for the idea's all have helped , I will look in to the tap and thread later but for now I used a ring terminal Dia:4.3mm which the carb screw went threw. threaded the wire threw and crimped the end .little twist end bit of wire and done.
olly
