Kombi Vs beetle tranny in buggy
https://forums.aussieveedubbers.com/threads/869/kombi-vs-beetle-tranny-in-buggy
dbmanx ·
Bought a buggy and am in the process of rebuilding. I'll be driving mainly in the city, but will go off road a little. It currently has a Kombi tranny (with spider gear) which is supposedly fine. Should I keep it or put in a beetle tranny in. If so what should I pay? Will the tranny gear let drive at a decent speed on roads. Any info would be great as I'm still learning
dbmanx ·
What speed can I comfortably drive in kmh with a kombi box
Buggy Boyz ·
You need to tell us which kombi transmission ? Are we talking IRS or swing axle ?
dbmanx ·
Swing axle from the 60's
Buggy Boyz ·
we are talking reduction hubs ? are the big or small nut boxes ?
dbmanx ·
I've been told that it is a 60 - 63 box.
Baja Wes ·
dbmanx, I think what you meant to say at the start was it is a reduction gear box, not a spider gear. A spider gear is the two gears in your diff, all gearboxes (non lsd) have them.
The reduction hub gearbox you have is no stronger than a beetle one, as it is basically a beetle gearbox with the diff flipped and different axles.
If you go to a beetle gearbox you will lose a lot of the ground clearance you must have at the rear at the moment.
Early (60-63) reduction hubs varied between 1.68:1, 1.40:1, 1.38:1, 1.26:1. The later ones (63.5-67) were all 1.26:1. The safe speed you can do on the highway will depend on what tyre size and reduction ratio you have.
Mad Manx ·
I have a type one box in my manx at the moment which is geared a little tall for my likings- but great high way speeds are not recomended as buggy's are too light and not very aero dynamic- I wont take mine over 80mph as the front end starts to lift and skip a bit ( rather frightening at that speed).
