Aussieveedubbers · Bugs
Wiring harness for VW beetle
https://forums.aussieveedubbers.com/threads/86900/wiring-harness-for-vw-beetle
Chop Top VW ·
Does anyone know where i can get a new wiring harness for a VW beetle
Also my car is 68 chassi and 64 body, doe the 62 model harness fit.
thanks
HappyDaze ·
Make sure that you pull a draw-wire through - attached to the old harness, when you remove it. It will make it easier to fit a new one. I think the RH drive harness is different to LHD?
vwsteve ·
im pretty sure 68 will have a lot more wiring than 62
Sides ·
Heh... prolly won't need a pull through wire on a convertible Greg !!!
RHD and LHD harness's are definitely different, and a 68 harness is definitely different to a 62 (regulator under the back seat... more fuses... emergency lights etc.)
You'd probably want a 64 harness really, tho a 62 would basically be the same I think (no real big electrical differences in those years AFAIK)
Have you tried the usual places here like Vintage VeeDub, Classic, Mick Motor's etc. ???
Chop Top VW ·
i found one at vintage wiring harness in melbourne but they only have 62 model, they said that they can add more wires if it needs it.
not sure what to do
Chop Top VW wrote:Does anyone know where i can get a new wiring harness for a VW beetle
Also my car is 68 chassis and 64 body, does the 62 model harness fit.
thanks
IT WOULD IF YOU ARE WIRING IT AS A 1964 BEETLE...
HEADLAMP DIPPER ON THE FLOOR...
starter switch in dash..
fuse box would be the same... etc
not sure where the regulator is...
without looking it up..
Chop Top VW ·
no regulator as im running an alternator, so it should be the same...
Sides ·
According to my Gregory's manual the wiring diagram for a 62 and 64 are the same.
So you should be OK if your car is wired as a 64.... where are your high beam and ignition switches at the moment ???
Oh and Lee... 62 and 64 both have the regulator on top of the generator.
Chop Top VW ·
my high beam is on the floor next to the clutch and the ignition is near the ashtray
Sides ·
OK, cool - sounds like she's wired as a 64 then.
Sides wrote:According to my Gregory's manual the wiring diagram for a 62 and 64 are the same.
Yes
they say the beetles in Australia up to 1967 were actually a 1962 beetle... with only minor changes..
lol
alternator makes it easy...
Chop Top VW ·
thanks guys, ill order the 62mod
Camo ·
Chop Top VW wrote:thanks guys, ill order the 62mod
Can you disclose how much they are after for the wiring harness as I need to do my 61 Beetle. I was thinking of making my own complete wiring harness as I will also be having electrically operated oil temp, oil pressure, tacho, and battery voltage.
Surely cant be that hard to run a dozen or so wires through the roof and connect to whatever. Just make sure I have numerous wiring colours and record what I connect them to.
Also is the 62 wiring harness made for 6V or 12V. I know people say its ok to run 12v through 6v wiring, but I would rather a heavier gauge wire.
Cheers, Kev
It is not just volts that makes the wire require heavier gauge. It is Amps. So a 6 volt wiring loom can easily run 12 volts.
Chop Top VW ·
hi camo,
$479 plus $16 delivery
waveman1500 ·
Camo, the 6V wiring would actually need to be heavier than 12V, because it has to carry twice the current (amps) to deliver the same power. This is why the car makers are keen to go to 48/60V in the near future. Running four times the voltage means that you only need 1/4 of the amps for the same power rating, so your wiring can be much thinner and lighter. This comes in handy when you're talking about 10kW alternators and similar things.
angryelmo ·
i just ran 7 core trailer wire down the back through the roof chanel. i run all electric gauges and thaco on a subaru motor and seams to be fine, whats more only cost me 30 for 10m or wire, a lot cheaper even after i bought solder shrink wrap and crips than buying a loom that didnt even have enough wires for what i needed.
only problem that it creates is knowing what goes where.
the dipper swich on the floor, does anyone know how it is ment to be wired up?
German Bug ·
Camo,
for that money, you would be better off with the Watsons Street Works loom. Given the strength of the Aussie $, its a lot cheaper and no exposed terminals.
http://www.watsons-streetworks.com/vw.beetle.wiring.html
Camo wrote:I was thinking of making my own complete wiring harness as I will also be having electrically operated oil temp, oil pressure, tacho, and battery voltage. Cheers, Kev
For extra wires for gauges etc I use 7 core trailer wire from front to back, also the wires run along the floor next to the heater channels, not in the roof.
Camo ·
German Bug wrote:Camo,
Just looked at this site thanks, but it appears to be only left hand drive.
Steve, thanks for that tip. Does your 1303 run any wiring through the roof.
Kev.
barls ·
didnt das use one on his 63 that he did?
Camo wrote:Just looked at this site thanks, but it appears to be only left hand drive.
Kev.
Hi Kev
It only runs the interior light wiring in the roof.
kieranweston ·
Chop Top VW wrote:my high beam is on the floor next to the clutch and the ignition is near the ashtray
is that what that foot push button is next to the clutch?! ive been wondering what that is!
Camo ·
I just bought a wiring harness from Richard at V-Force.
Kev
