got a 32/36 weber on a beetle 1600 run fine but the linkage setup is crap anyone got a pic of how they have oe setup so i can fabricate something
vwo60 ·
i fabricated this linkage and aircleaner to fit into a 36HP engine bay, uses the standard cable, with a shaft pivoting across the back of the manifold and a short ball joint linkage to pull the carb actuation arm, work perfectly
btc-er ·
Interesting setup. Do you have any more photos?
I've done a few with a longer cable going around a pulley and then back to the throttle.
been years - but I thought my prog just connected straight up??
OZ Towdster ·
Mine always hooked straight up too , but mine was fitted 180 deg around to how vwo60 has his fitted , with the main benifit of it being reversed as with vwo60's , that you can at least get to the idle jet .
But if you run a good fuel filter and arn't pulling the Carby apart everyother day then the idle jet placement although difficult to get to is not that bigger problem
barls ·
fit the webber copy off a lada niva. bolts on with linkage in the right spot and all adjustments at the back in easy access.
jsheppard64 ·
sorry... but is it a DFEV or something
mine is a DGV5a (throttle turns other way) I ended up making my own manifold because the fuel surge around when i turn its fitted with the float side facing to the front of the car
bnicho ·
Yes, these carbies are supposed to have the flat facing the front of the car. I always wondered if fuel surge is a problem when they are placed the other way around.
Also, is icing up a problem with these carbs?
I have used these carbies for years on other cars and I have plenty of spares. But I haven't dared fit one to Olive yet.
