waveman1500 wrote:Common oil leak spots are from the sump plate/bolts/plug, oil cooler seals, rocker cover seals, pushrod seals and front or rear main seals. The first thing I would do is wipe it all clean and then wait a while for some oil to leak out so you can see where it is actually leaking from. If the top of the heater boxes is caked in oil then you should check for leaks from the rocker cover. Rocker cover gaskets and sump plate gaskets and seals are very cheap and can be replaced easily. Most of the other leaks require a bit more work to fix, but it can all be done.
cheers mate will have a look and see. where can i grab push rod seals?
