Aussieveedubbers 路 Buying, Selling & Swapping Parts
WTB BJ Narrow beam with drop down spindles would be bonus
https://forums.aussieveedubbers.com/threads/86971/wtb-bj-narrow-beam-with-drop-down-spindles-would-be-bonus
dbmanx5 路
Hi,
As title says I am chasing ball joint narrow beam with tie rods etc. Drop down spindles would be a bonus.
Live in Vic car is in SA please PM if you have anything.
bajachris88 路
with USD and AUD on par... nows the time:
$300 from cip1.com. Probably be about $250 shipping to your address:
http://www2.cip1.com/SearchResults.asp?Search=narrow+beam
brand new ready to go.
馃憤
matara 路
For a LHD car yes 馃檪
dbmanx5 路
That was my concern as well. For LHD?
bajachris88 路
it is for LHD... everything should be the same as RHD except the steering damper mount and the welded on bracketry behind the two beams in the middle of the other side (see ad for what i mean).
It would be alot easier to graph on the lhd appropriate brackets to a beam like this from your original then to cut 4 parts of the two tubes, shorten, fit adjusters weld it all up together etc. etc... and wouldn't require as precise workings. It would be alot cheaper for someone to do that for you than to shorten your stock lhd beam (in regards to time and labour). Depends what you got though, more money than time or more time than money.
It comes with adjusters and fresh bearings, isn't a remanufactured unit, its a brand newie.
just an idea... 馃檪
