Aussieveedubbers 路 Non-VW Engine Conversions
fastback with Subi 5 -speed box????
https://forums.aussieveedubbers.com/threads/87032/fastback-with-subi-5-speed-box
chris7 路
Iam thinking of turning to the darkside..and converting my 72 fasty into a wrx power plant like the previous post!!...Will the 5-speed box fit aswell...sorry if this post has been done before iam still new to this!!馃槑
ttriebler 路
Yep should fit as the subie 5 speed is basically the same size as an 091 box. Happy to send you a dummy subie box with no internals if you want to mock up before making your final decision to spend the $$$
chris7 路
yeh that would be great..in the process of stripping my car for resto...priced up the vw 1916cc option....but leaning towards the wrx option looks fun...iam thinking of buying a front cut subaru? would that be my best option?
just dropped the old engine and gearbox out of the the type 3 both need a rebuild so gonna go the subbie route i think...any advice welcome
chris7 路
Thanks for that by the way 馃憤
chris7 路
Just checked out the website mate and I want that for my car!! do you sell the mounts? will they fit my type 3 and what price are they? haha ...not to many questions i hope馃槀
ttriebler 路
No dramas. I don't do the mounts, I want to focus on doing the tricky stuff and let shops or home mechanics do stuff like mounts - hence I have published the plans and measurements of the type 1 mounts. I've not done a fastback one yet so these would have to be developed.
Be a good idea to purchase a front cut, that way you get everything you need. Just don't buy one with a hi/lo dual range gearbox as these can't be reversed.
barnbro 路
ttriebler wrote:No dramas. I don't do the mounts, I want to focus on doing the tricky stuff and let shops or home mechanics do stuff like mounts - hence I have published the plans and measurements of the type 1 mounts. I've not done a fastback one yet so these would have to be developed.
Hi its Todd i belive, Ive been folowing the bus thread clyde in the states is doing to the t25 hes come up with a souloution for the shifting but hes got it where 5th is meant to be 1st gear is there from what i understand and you have got it right in the sharp built buggy cant you just some how use the bug shifter and rod back to the subie box i own a splitty and was considering you conversion but i dont want to have the wrong shifter patern can you please advise . Angelo
Birdman 路
Hi Barnbro,
I don't know how the shifter works in a slit bus but there are no problems in a beetle install. If you connect the shift rod direct to the gear box all the gears are in the right place. Hope the info helps your install
barnbro 路
Birdman wrote:Hi Barnbro,
Thanks for the reply Birdman i know it works in the t1 i saw the sharpbuilt buggy in action but i got a t2 and need to know if any one has done this conversion with the same results as the t1 with the shifter assembly cheers Angelo.
ttriebler 路
Hi Angelo, nobody has finished this conversion in a bus yet and the first one to be finished is a cable shift version. The key to getting it to work in a bus is using the type 1 ball and socket arrangement that they have with their shifter/shift rod. This reverses the action of the vw shift rod and makes everything shift beautifully.
I would be happy to take a look at this with your t2 with you if you are in Sydney so you know you have a bolt in conversion before you commit to the funds for a subie box.
ttriebler 路
By the way the sharp built buggy is back in action with a new subie box (the first one is now in an ej22 beetle up the central coast). I'm told by the sharp built buggy owner he did a nice 6000 rpm rev and dump launch today and the torsion LSD kicked in smoothly, rotated both tyres about 1 revolution and he took off down the road.
I had quite a few people ask if an LSD diff would work in a 'flipped' transaxle and it's always good to see the theory actually proving itself true. 馃檯
barnbro 路
ttriebler wrote:Hi Angelo, nobody has finished this conversion in a bus yet and the first one to be finished is a cable shift version. The key to getting it to work in a bus is using the type 1 ball and socket arrangement that they have with their shifter/shift rod. This reverses the action of the vw shift rod and makes everything shift beautifully.
thanks for your reply im a bit far off for the motor and box at the moment but as soon as ive got the body done i will be giving you a call to sort out how best we can attack the transplant cheers angelo.馃槑
