F/S Porsche 944 rear suspension & brakes
https://forums.aussieveedubbers.com/threads/87063/fs-porsche-944-rear-suspension-brakes
CH5353 ·
Porsche 944 steel rear trailing arms, brakes complete with discs, calipers, dust shields and hand brake including cables. Fits Type 1 IRS as a bolt on package using 5 x 130 Porsche stud pattern. $800 pr
IRS 23.5 mm torsion bars 26 9/16" long $100 pr
Porsche 944 turbo calipers 4 piston Brembo alloy uses 290mm x 24mm disc $400 pr
Porsche adjustable spring plates for IRS $100 pr
Other bits and pieces for brakes and suspension.
Will post photos when camera fixed Can deliver to DOVW
John 0419 168 914 Bendigo Vic
CH5353 ·
Torsion bars and spring plates sold.
Might have some others in the back shed.
BiX ·
Are the rear brakes with the arms turbo or NA?
Are the turbo brakes rear or fronts?
I am interested if your willing to box them for shipment to Brisbane.
CH5353 ·
BiX
Rear arms are NA steel, exactly the same as Type 1 IRS. I do have some Turbo alloy arms, I was told they were 86 but they are 87 on, casting date late 86, they have hand brake, stubs and hubs.
944 Turbo calipers are rears, fronts use 28mm disc.
Have front struts complete with brake calipers etc off 924 Turbo which are the same as 944 NA
I think they are the same as either 1302 or 1303 Superbug with 2 bolt spindle mount.
Have had a prior enquiry about the arms, you are next in line.
Freight to QLD should be no worries, local bloke I know goes there every 2/3 weeks. Next trip in 2 weeks to Airlie Beach.
BiX ·
Do you have the part number on the calipers? are they the earlier calipers?
sent an email to you.
