Does anyone know how difficult it is to replace the shift coupling in a bay window Kombi. I have changed one in a Beetle and it was a piece of cake, but I have read that I may need to remove the engine and transaxle to do the same on a Kombi.
Jamie
vwsteve ·
nah mate, another piece of cake, 1 at the front and another at the rear, i did mine after a year of swearing changing gears
h ·
rear one is easy as n the most likely IMO to be in need of newness..
hop to it
jamsha71 ·
Are you guys talking about the coupling or the nylon bushes? There's just one coupling, right?
I'll replace the lot I think, especially if the bushes are so easy.
forry2000 ·
try to keep the rear metal cage part if it is VW german, the new brazlian and even so called german ones are crapola.
just replace the rubber.
pod ·
yep if your going to change the rear you might as well change the front bush as well ,it makes a hell of a lot of difference 👍
