Wheel bearing IRS... Inner
https://forums.aussieveedubbers.com/threads/87099/wheel-bearing-irs-inner
Aussie Dubbin ·
Hi All,
Last night i stripped down the diagonal arms on my bug and want to removethe inner seal CV sid and then the last bearing behind the c-ring...
Any suggestions for rmoving the seal? it is not buging???
Also, wil the last bearing come out easily enough if i remove c-clip?
bajachris88 ·
persistance for the seal. trying to pry off by knocking under the groove of where it sits. driving a flat head into there then levering, whilst not to impose any damage to the arm, but its pretty tuff steel.
the last bearing needs to be tapped out with a hammer, after teh circlip is removed. its straight forward 👍
When refitting just remember to fit the spacers the right way and ur set.
