steering column view
https://forums.aussieveedubbers.com/threads/87218/steering-column-view
grogy ·
hi . does anyone know of an online web site that has exploded view of early bug/ghia steering column/ shaft etc. thanks greg
Old Dubber ·
What bit do you want to see? and how early?
grogy ·
hi, basically from the top of the column to the bottom inside view. i pulled the steering shaft with the wheel still connected out and the bearing fell apart, it seems to have a spacer a small tin spring type clip a spacer with a cut out obviously fits in with the cut out in steering wheel. i writin this by memory cause my comp died. anyway a good pic would be realy helpful. to make sure its assembled correctly. thanks greg... ps 62 model
Camo ·
Dont know if this will help or not.
http://www.thesamba.com/vw/forum/viewtopic.php?t=369613
Kev
grogy ·
thn i gret....................... computer br.oen
