started a project and after getting the body on a rotisserie and blasting it had to through it away...bog gallor. Do you have an early type 3 body?
vlad01 ·
you gave up and through it out?
type3hunter ·
its on the scrap. too much pannel work
Edison ·
What are you looking for?? Another Notch??
hellbugged ·
vlad01 wrote:you gave up and threw it out?
x2
good luck finding one that doesn't need rust or panel work.......
vlad01 ·
another one bites the rust 😢 RIP lil notchy.
YOU monster!
type3hunter ·
Hi Edison . Yes mate,Chasing another early notch.
type3hunter ·
Stripping a car and going down the path of the 'fully fledged resto', sripped and blasted on a rotissorie...are not exactly the trade markes of some one who easily gives up or balks at a challenge. your too emotional vlad...
as if it was an easy or fun decision to part with the body
vlad01 ·
did you at least cut good sections out to use or sell to others needing them?
Klaus ·
wow first notch I've seen without rust around the rear window , goodluck finding another shell.
There was one on here forsale awhile ago green in colour i think and one was on ebay in cooma nsw looked pretty clean.
type3hunter ·
Ive been keeping an eye on ebay...any sugestions or info on anything available is much appreciated
Klaus ·
its still on ebay all pulled apart $500 at the moment 68/69 model.
I've got a 64 but its a way bigger project bog is the least of my worries I'd rather it be just bog 🙂
AzzA_teu ·
Klaus wrote:its still on ebay all pulled apart $500 at the moment 68/69 model.
Can you make sense of that ebay listing?
I think I'm a bit slow, because I don't really understand what he's done to the car thus far. I even sent the seller a message but am now even more confused. Maybe I'm over thinking things.
Is the car just a '68 model with a '73 pan but still using the original '68 real swing axel? Anyone know if that'd cause any issues with getting it re-registered?
Sorry about the thread hijack 😵💫
Klaus ·
rear subframes can be swapped out , there arent too many adr's on a 73 so wouldnt be a big deal, heater controls and seat runners are diff though as is shifter base (easier to do shifter bush) . But later pan will bolt up no worries.
