drum brake removal
https://forums.aussieveedubbers.com/threads/87310/drum-brake-removal
DPV2010 ·
I have got a buggy that I want to remove the drums and service the brakes and replace pads. I cant seem to remove the lock nut - i assume this is the correct nut to remove?
any tips?
dogo ·
Left hand thread!
hellbugged ·
left hand thread on passenger side only
If you run a speedo, be sure to seal the cable on both the stub and grease cap sides with good quality silicon
This will prevent water from getting into the bearings.
DPV2010 ·
I tried forever today! and then i eventually found it, thanks heaps - who woulda thought! left hand
dogo ·
If you ever buy yourself an early valiant they have left hand thread wheel nuts on the left side!
hellbugged ·
just inspect the spindle threads to be sure they have not been damaged during your attempts
DPV2010 ·
Thanks heap for all the help!
