Aussieveedubbers 路 Bugs
17x5.5 wheels on a beetle
https://forums.aussieveedubbers.com/threads/87416/17x55-wheels-on-a-beetle
Chop Top VW 路
Hi Everyone,
Has anyone ever fitted 17x5.5 wheels to a beetle, woukld they fit ok and what size tyres would fit.
the beetle is 1964 body with 2.5 inch lowered spindel
thanks
STIDUB 路
first i want you to show me where your getting 17x5.5" wheels from!
then
http://www.1010tires.com/TireSizeCalculator.asp
punch in your current size tyre then work from there, i cant say ive seen much in the way of skinny 17" rubber
also useful...
http://www.willtheyfit.com - for a rough idea what your wheels/tyre combo will look
and
http://www.1010tires.com/WheelOffsetCalculator.asp useful for offset changes, stock is approx +36
hope that helps
and mods PLEASE STICKY THESE LINKS WHEEL/TYRE COMBO QUESTIONS COME UP WAAAAYYY TOO MUCH!!!!!!!!!!!
thankyou 馃檪
Chop Top VW 路
im getting them custom made (billet wheels)
STIDUB 路
and tyres? narrowest 17s excluding space saver rubber i see is 205/40... that may end up looking quite strange, might be worthwhile going 6.5 wide at least...
vwo60 路
A 205 should fit a 7" rim, you will still end up with the same tyre width with the 5.5" rim, good chance of having it come of the rim.
barls 路
i use to run 205s on my 15 x5.5 with no problems
waveman1500 路
I'd agree with STIDUB, make sure that you can use a readily available tyre size. Custom-made wheels are fine, but you can't get your tyres custom made every time you need a new set! I haven't found or heard of any 17" tyres narrower than 205mm section width, which ideally needs a 7" wide rim. On 5.5" rims they may not fit correctly.
waveman1500 路
barls wrote:i use to run 205s on my 15 x5.5 with no problems
But what was the aspect ratio? With a 15" rim you will have a much taller sidewall, which allows for a much wider range of rim widths to fit. With a full inch out of the sidewall height, a 17" rim will be much more picky about what rim width it will fit on in my opinion.
1303Steve 路
Tyres will be the issue. I was pricing some rear tyres for my sons Skyline, popular car sizes are cheaper. 225/45x17 $95 each or 255/40x17 $145 each.
Joel 路
Agreed, stretching the tyres outwards is bad enough without going the opposite way.
Dunno what these custom made rims are gonna cost you but you may find they're one expensive defect.
