rabidbeetle wrote:Hi all,
Have to drill holes in my front bar to fit the number plate will a standard drill bit do the job and will this cause the chrome plating surrounding the new hole to flake off or be damaged?
What the best way to do this?.
Thank you
it depends on the chrome...
the original thick VW bumpers are fairly hard to drill...
use a small drill bit first 3 or 4mm then use a 6mm and once the hole is drilled move the drill around so the hole will be slightly larger so a 6mm screw or bolt will fit...
I've never drilled a brasillian or mexican bumper so I don't know what they are like...
I know they are much thinner than the German made bumpers.. and much weaker...
stainless steel screws and washers should stop the chrome from lifting if it looks like it might...
