hey fellas
just looking for a type 1 front beam
or know of wreckers around goldcoast Qld area i could check out.
vwsteve ·
ball joint or linkpin?i may have 1, steve 0409475131
bushed ·
have a 60's l/pin nr Bris comin not sure of cond
beam only or dr 2 dr?
pudgy ·
I too have a link pin in Brisbane which has adjusters fitted. Currently it also has a Whiteline sway bar and almost new Konis, but I could split to the parts you need,
oztype3 ·
well my plans are to rebuild the beam and fit an airbag on their.
not sure on the difference on link pin or ball joint. as the work is being done proffesionally..
by adjuster that means its had the middle section cut out and that nut system ( quicker way of lowering it)
im not 100% sure on what you mean
its going on a type 3 squareback
pudgy ·
Yeah it is the cut and weld in type nut adjuster system. From the sounds of what you'd be doing it'd be better to just start with a bare beam. Mine has been rebuilt etc., so would suit just installing in car straight up.
