Return fuel line size
https://forums.aussieveedubbers.com/threads/87494/return-fuel-line-size
beachbuggy61 ·
Howdy.
I've finally got around to setting up the holley blue fuel pump with the malpassi rising rate regulator to ensure I have fuel pressure 3lbs greater than boost. All good.
Now for the problem. With my old solid state facet pump (max 4lbs or so) in the system, I can adjust the pressure with the regulator anywhere from 1 to 4lbs easily, and when I set it to 1 lb, I can hear the excess fuel running into the tank via the return line. However, when I put the Holley pump into the set-up, it blows the pressure over 15lbs even with the regulator turned all the way down!
I've run a new supply line through the tunnel (5/16") line, and am using the old supply line (I think they're 1/4") as the return line.
I'm at a loss. Is the return line too small perhaps or is there something wrong with the pump? I'm sure the regulator's ok and the fuel pressure gauge, because I can adjust pressure easily with the facet pump.
All help appreciated.
Thanks, Marc
66brm ·
Where does the stock line return to the tank?, it sounds like you have some sort of restriction in there, a filter or dodgy flex line? What are the specs on the new pump ie flowrate @....psi?
Sides ·
Everything I've ever read says return line should be the same size or larger as the supply line.
http://go.mrgasket.com/pdf/TS_FuelSys.pdf
My understanding is if the return line is too small then the regulator just can't bleed the pressure off quick enough, which sounds exactly like what you've got.
beachbuggy61 ·
Thanks Dave, you're dead right I've since discovered. I put a 5/16" line on the return of the regulator and ran it into a bucket just to see if that would fix it and I was able to set the idle pressure perfectly at 3psi.
Now all I have to do is run ANOTHER 5/16" line from front to back for the return and ignore the original line altogether. I thought it was fairly easy threading the first one through past the pedal set and the other bits and pieces inside the tunnel.... a second one is going to be real fun! Wish me luck.
Thanks again for your advice.
Oh. 66brm, the return line feeds into the top of the tank, I've mounted a 5/16" bulhead fitting in there.
Cheers, Marc.
66brm ·
Cool, hope you get it sorted, I'm just about to tackle the same job on my oval, 5/16 feed and return but for a 2176 efi donk
beachbuggy61 ·
All done! The second 5/16" line went through a breeze. Just had to cut an extra hole at the back for it to come through. Fired it up, pressure good at 3 psi and we're away.
No I just hope it does as advertised and gives me correct pressure under boost!
Marc.
