WANTED- Narrowed beam - BALL JOINT F/END
https://forums.aussieveedubbers.com/threads/87497/wanted-narrowed-beam-ball-joint-fend
patina ·
Hey guys,
i need a narrowed beam to fit on my:
1970's ball joint front end beetle chassis.
Does anyone know of someone in Australia who fabricates beams as i would rather get one here than from the US,
due to time.
CONTACT:
NAME:
lauzboy ·
do you want a new fabrication, or modification of an existing?
captainvw ·
Shocks or no shocks ? How narrow?
VVDS stock 2'' narrowed CB Balljoint beams with Shock towers.
patina wrote:Hey guys, i need a narrowed beam to fit on my: 1970's ball joint front end beetle chassis. Does anyone know of someone in Australia who fabricates beams as i would rather get one here than from the US, due to time.
Yes,
there was a beautiful looking narrowed beam on here last week
it had been made...
wasn't a modified VW one....
although its much quicker to modify the front end You have...
Someone on here should be able to help You..
captainvw ·
Yes,
it had been made...
You mean much slower considering you chop the centres between your uprights and your shock towers to narrow a balljoint beam Lee i doubt you'll find someone willing to do it for less than the cost of a new Cb beam.
lauzboy ·
how much is a new one (including shipping)? remember your torsion leaves also need to be cut down too, or order shortened ones
i had mine ball joint beam narrowed and adjusters welded in at CBB in penrith. vaguely remember it was around $400ish which included disassembly, the mods, castor shims, reassembly and wheel alignment
vwo60 ·
If you narrow the beam it will have to be engineered, as i understand it you will have trouble convincing a automotive engineer that narrowing the track with not change the handling and safety of the car.
