Aussieveedubbers 路 Tech Talk
gear box help diagnosus please
https://forums.aussieveedubbers.com/threads/87514/gear-box-help-diagnosus-please
phatratpat 路
coming home from work today in the 58 beetle shifting
from 3rd back to second,lost all gears ?
engine runs but as I shift through the gears she will not engage...shift feels fine but nothing !!馃槧
what do you think....clutch only 3 mnths old !
input shaft ?.....OH its a type 3 box mated up to a 1500 singleport..............open to suggestions
vlad01 路
did you fell anything let go? like a pop or clunk?
phatratpat 路
NO ! thats the problem gears one minute gone the next !...although I did have the stereo up pretty loud
had been detecting an intermittent vibration coming and going since I did the clutch !
Gracey 路
Not sure, but check the shift rod coupler under the rear seat.
johny rotten 路
Check the drive splines in the brake drums
look for a loose axle nut
h 路
shift coupling under rear seat pat..
look there first n happened to me many moons ago
maybe an easy fix
phatratpat 路
first thing I checked Paul ,all good ! hows the herpies ?馃憤
h 路
huh wtf?
was that the problem?
i have cream but did you tell ur wife?
$2.63 homebrand baja 路
Sprays some glen20 into the thread then posts...馃
'This one time on band camp" I had 'issthues' with a clutch plate, had the oldskool adjustable tab thingies...after putting the engine back in the thing ran like shiet, and gears were hard to engage etc...thought I broke some strange sprocket on my thinimiebob wtf is going on PANIC etc 馃.....so--oo took engine back out and checked it all out, and one of the nuts hadn't been tightened properly, so a tab was loose on the plate, so the plate was sitting crooked/uneven preassure so re-set it all and tightened it up properly...or do you have the new fangled whizzbang spring loaded type?
may not be of much use...but I know it freaking vibrated when it was wrong....馃槧
matberry 路
Oh no....h has herpies....might need something stronger than Glen 20. 馃槀
Napalm 馃シ
hehe, haven't engaged in public forum grosities for a while....mmmwwaaahahaha...nah-nah-nah-naahh-nah h has herpies...h has herrrpies....馃檯
h 路
happy to share the love
I'm sure the host pat is closer than where I'm at in mother Russia
I can email you a swab if ur in needy dire 馃
oooh yethie pleezeee... I shall take it and sell it on ebay as tony 'bom chicka wah wah' abbot's DNA swab.........................馃憤馃シ with no reserve i might make 3 cents from some budgie smuggling nerd aming for world domination by cloning a tony army.....馃 won't that nerd get a surprise in his petri dish! 馃檯
h 路
so pat was the shift coupling In need of mc lovin?
dangerous 路
sounds like something related to the input shaft.
Probably the throw out bearing or clutch,
or even the sleeve that joins the input shaft to the mainshaft inside.
phatratpat 路
so what youe saying is,the donk has to come out ! ! again......@&^(*@*馃檯
vlad01 路
be grateful that you have a vw where if only takes 45min not some bs modern water pumper that takes 2 days to take out.
waveman1500 路
Have you looked at the driveshafts and CVs? If the shift feels fine and there's a complete lack of drive then it could be on the output side.
