Thinker ·
has any one come across a good way to clean out a blocked heat tube on a single port manifold. i have managed to get in about 6 inches from each end only.
https://forums.aussieveedubbers.com/threads/87533/help-heat-tube-blockage
Thinker ·
Thinker wrote:has any one come across a good way to clean out a blocked heat tube on a single port manifold. i have managed to get in about 6 inches from each end only.
waveman1500 ·
doesn't it get cold in Adelaide???waveman1500 wrote:Mine rusted through on the outside and was leaking exhaust gases, so I just used a gasket as a template to cut out two bits of galvanised sheet steel. I put the galvanised sheets in with the gaskets on the exhaust side to block off the heater tube and did it all up tight. Job done! This was last summer, and I haven't had any running problems all winter.
Thinker ·
were abouts would one get one of these manifolds.vw54 wrote:if its a 1500 inlet u can buy a new one pretty easy
1200 and 36hp are harder to find
Stephen62 ·
Thinker ·
