im doing a top end rebuild and currently have plastic spring type tubes.
i am going to replace them but what with
stock
spring loaded alloy
or
screw up type
Thinker ·
https://forums.aussieveedubbers.com/threads/87560/which-push-rod-tubes-to-use
Thinker ·
sander288 ·
STOCK ONLY....Thinker wrote:im doing a top end rebuild and currently have plastic spring type tubes.
stock
spring loaded alloy
or
screw up type
Thinker ·
waveman1500 ·
Thinker ·
HappyDaze ·
and it will be again.... stock as a rock ...😂😎Thinker wrote:this is what i wanted to here🙂
vlad01 ·
vlad01 ·
Nice but $$$$$
HappyDaze ·
They'd be just the job, if you're after a very high impression ratio.😎
vlad01 ·
Thinker ·
kieranweston ·
fish26 ·
dangerous ·
This is what i use, and 1200 tubes when high comp or short barrels.waveman1500 wrote:Stock tubes, the original and the best. Use new tubes and seals and install them correctly and you should have no problems.
