Brand new 2800cc type 4
https://forums.aussieveedubbers.com/threads/87640/brand-new-2800cc-type-4
RodPenrose ·
I have a complete 105mm x 80mm type 4 engine here I have not had time to install in my bus . It has a Scat c35 camshaft , lube-a-lobe lifters , 105mm JE pistons , Scat H beam rods , Fat Performance crank , porsche cooling kit , 48mm IDA carbs , 200mm flywheel , Squareport heads , 48 x 40 stainless valves ported relocated plugs , and a lot of other good parts . I would like to get $ 9000 for this engine that is located in Wollongong NSW , ROD , 02-42729920 .
vwsteve ·
just what i always wanted, if only i had money
HappyDaze ·
Crikey Rod, that would be the go in 'No.8' Beetle❓ By the way, - I won't tell anyone - you left off the post code❗ The death penalty still applies, I think.😂😂😂😂
LUFTMEISTER ·
crucifixition.....1st offence
The "comfy chair"......2nd offence
2 weeks in woolongong... 3rd offence
4 weeks in woolongong ...4th offence
sweet sweet death (after the gong)......5th offence 🤪
typ268 ·
Would this go into a 1960 bus?
Could I get it registered with a brake upgrade?
What else would I need to do?
Thanks.
typ268 wrote:What else would I need to do?
get NRMA membership 😂
its worth it for all older cars 🤓
johny rotten ·
yep go with NRMA Gold 😂
johny rotten ·
typ268 wrote:Would this go into a 1960 bus?
Thanks.
Yeah Get Wayne to do the Blue slip 😊
tell em its a 1700
typ268 ·
Thanks for the help.
So its a no go then?
hellbugged ·
typ268 wrote:Thanks for the help.
give Rod a call (the seller of this engine) he will be able to answer your questions and probably have alternatives if this motor doesn't suit.......
