Aussieveedubbers 路 Buying, Selling & Swapping Parts
beetle & type 3 engine parts, piston ring grinder, for sale Adelaide PRICE DROP
https://forums.aussieveedubbers.com/threads/87666/beetle-type-3-engine-parts-piston-ring-grinder-for-sale-adelaide-price-drop
type3lover 路
Price: as below
Condition: new and used
Contact: post here, PM or email
Description: as below
Hi all,
I have the following parts available for sale. I will post anywhere or can be picked up from Grange 5022.
1: CB performance Eagle #2234 (turbo grind) camshaft with lightweight racing lifters and straight cut gears, all only 92 miles use NOW $125 the lot or will separate
2: Engle lifters - set of 8, 28mm bases - suit 1300,1500,1600 engine - brand NEW $50 - less than what I paid from cip1.com.
3: Aluminium cam gear - brand new $25
4: Beetle disc brake backing plates - brand NEW $30 pair
5: Beetle window lift channels brand new *SOLD*
6: SOLD
7: 12v crankshaft - used. All journals STD and ready for regrind $40 good core, not cracked. cost me $50
8: type 3 camshaft with original "zero" cam gear, removed from 46000 mile engine $40
9: Early type 3 ignition switch with key. works perfectly $30
10: SOLD
11: Piston ring file - used once only. Cost me $110 now selling for $70
12: Cylinder "kool tin" - copy of the late type 3 cooling tin that goes under the cylinders, few scratches where i tried to fit it, but in the end I used the VW stuff. bought from vwparts.net $15
ALL PRICED TO SELL!
Thanks, Toby 馃憤
type3lover 路
Window channels sold...
square73 路
Don't happen to have any other t3 stuff about do you? Need late model front guards. I am in Adelaide. Cheers, Marty.
type3lover 路
Hi Marty
I have no panels, but do have bits and pieces like bonnet and boot latches and small items as well as some efi odds and ends.
Try "splitmeister" on the forum here. He's in Adelaide and may have a few bits that you need, otherwise you could call or visit Volksfactory at Holden Hill.
That's all I know. Good luck!
zocstar 路
If the tail light bases are all good I'll take them. They are off a square? The screws arnt seized?
Type3Sicko 路
Toby, you have PM regarding type 3 cam and gear for $45. Thanks, Adam
type3lover 路
Hey zocstar, sorry for not getting back to you sooner! The bases are good. one small blemish is all i could see. I think they might be from a square. Screws came out easily.
Adam, PM replied thanks mate
type3lover 路
bump
type3lover 路
make an offer
benfel 路
email sent
type3lover 路
email replied
