I am ONLY after the original Left and Right versions with blade holder ( I can buy the actual blade)
I am NOT after the the new aftermarket style that has flat blades. They do not work.
I have the longer left arm - but not the left blade holder.
Right Arm - short
Right Blade - long
Left Arn - long
Left blade - short
2 right arms I can work with as well
barry
donn ·
can do, pm me your adress, $20 + post or wait till Thursday I'll be in Sydney on the way to int. airport.
Done and you have PM
Hi Barry
After you after the Aussie made Tryco ones or the German style? The Aussie ones have a pin on the end, the German ones have a hook. I bought German ones from VW Heritage in the UK. I might have some Aussies ones floating around.
donn ·
No Pm, I'll check to see what type I have regarding Steves post.
pretty sure I dont care - the ones I have are the Australian version. If German are better than great
As lons as they are complete with arm and blade and take the universal slide in rubber blade you get from Autobarn
What I dont want are like the Bosh replacement ones
Donn
I will try again
These are the rubbish Bosh blades that I dont want
This is what I am after
donn ·
Got your PM. Looks like I have the ones you are after though they are black (bit chipped) a close up of the wrong type would be helpfull, not sure how the end comes off the arm, have tried but don't want to force the issue, they have those small tabs on the ends of the arms which look like they are meant to be spring loaded to remove the blade holder. I'll have to check our path to the airport as we will be in a bit of a hurry, you may have to meet me somewhere. Do you want all the rubbers?
Dont really have a close up as I threw them away
The ones I want have a single piece that the rubber blade slides in to
If you go Victoria Road way you pass VERY close to my place - then into the city - tunnel and you are there
The Original trico aust ones are all metal, those crappy replacements are plastic.
If you get really stuck I have got a pair of original trico ones but there abit worn in all the joints
donn ·
Ok these have the Trico stamp, looks like we are on a winner. 👍😀
I bought a set of wiper blade holders with an airfoil on them from Super cheap, I fitted them to my sons bug and they seem to be holding up really well.
When I started building my new 1303 I had a mishmash of wiper arms so I bought some from VW heritage, they still have them but they are 22.43 pounds each, yikes.
