Aussieveedubbers 路 Buying, Selling & Swapping Parts
WTD Porsche Wheel Caps
https://forums.aussieveedubbers.com/threads/87697/wtd-porsche-wheel-caps
Pumba 路
A long shot i know but im after 2 silver 3 prong early fuch wheel caps,i have found some in the states but i thought i will try my luck here first,im also after a set of beam adjusters for a beetle and drop spindles for balljoint front with drum brakes,i can only wish馃槀
cheers shane.
Bizarre 路
Pelican Parts 馃憤
Pumba 路
Had a look there,also found some on the samba,just thought someone might have 2 they dont need before i buy from the states.
crsedge 路
I bought mine from Magro Wheels in the States, good quick turn around.
You probably know, but there are different centre caps depending on whether original wheels or reproductions. I sent photos of my Fuchs Centres to Stan over there, and he organised what was needed.
Craig
HappyDaze 路
I've got a few odd ones - can you post some photos & dimensions? Or you could take a trip 'up the hill', and check them out.馃榿
Pumba 路
HappyDaze wrote:I've got a few odd ones - can you post some photos & dimensions? Or you could take a trip 'up the hill', and check them out.馃榿
I havent been up that hill in a while,the ones i have are the 3 prong,the lip that goes in the rim is 65mm the out side is 80mm and they are silver,i have a picture but to big to upload,do you want me to send to you???cheers shane.
Pumba 路
crsedge wrote:I bought mine from Magro Wheels in the States, good quick turn around.
Craig
They are genuine but they are 14inch.
cheers shane.
Pumba 路
Anybody got a adjustable ball joint beam for sale or i could swap for 68 up 1 peice door windows,single webber manifold,wide 5 to commodore adapters,sports wheel etc etc ??????
