kieranweston wrote:Hi, I have just reinstalled my 1500 engine with an alternator upgrade, does anyone have any ideas on wiring it up to the coil etc? I have tried to follow the labelling from when I removed the engine (when it had a generator) the wiring was a bit of a mess so looking to replace a few bits but would really like to know the main wires that need connecting, engine is turning over, there is fuel so im pretty sure im not getting a spark out of the coil
Thanks a lot for any help.
the wire from the condensor on the side of the distributor goes to the -- minus terminal on the coil...
the wire from automatic choke and electromagnetic cut off valve go to the + positive side of the coil... [power]
this will give You spark...
do You have a two wire alternator? [most common]
the small terminal and small wire go to the dash lamp...
this must be connected for the alternator to charge..
the larger wire goes to the battery..
the thick wire from the battery goes to the dashboard...
to power everything....
the voltage regulator under the back seat is no longer used..
or maybe it was located on the generator???
if it was under the seat:
the large wire coming off the regulator is connected to the large wire going to the regulator from the battery...
its best to solder these two wires together...
and cover with heatshrink or lots of PVC tape
or put yellow terminals with a round hole in the wires and screw them together and tape them up with a lot of PVC tape..
then cable tie them so they can't move about...
