body to chassi bolt sizes
https://forums.aussieveedubbers.com/threads/87758/body-to-chassi-bolt-sizes
oldnslo ·
Can someone please tell me the bolt sizes, as in length of the bolts that attach body to front beam, the 4 bolts that attach body to rear torsion tube, and the 2 at back under wheel well I need to purchase? Cheers thanks
Birdman ·
I would recommend a beetle wrecker for the beam bolts because they are massive, an odd size and not readily available. cheers
yep get some S/H ones for sure
oldnslo ·
BTW my car is a 1956, I might have them already in a box of loose bolts, just need to know the length of them
oldnslo ·
I think they are 25 mm long.I have 3 of them. Does this sound right?
11CAB ·
oldnslo wrote:Can someone please tell me the bolt sizes, as in length of the bolts that attach body to front beam, the 4 bolts that attach body to rear torsion tube, and the 2 at back under wheel well I need to purchase? Cheers thanks
Going from memory these are M10x1.5 Bolts..... nothing special and you should be able to get at any Bolt Place
oldnslo ·
cheers for that, much appreciated.
psimitar ·
Yep m10x1.5 pitch and 25-20mm long. Also they need to be high tensile.
