WTB emulsion tubes & jets for idf
https://forums.aussieveedubbers.com/threads/87765/wtb-emulsion-tubes-jets-for-idf
Arpspasm ·
Hey I am hoping that someone might have some jetting bits for a pair of 36 IDF webers gathering dust on a tin somewhere . I am after F11 emulsion tubes, 135 mains, 45 idles and 180 airs.
Cheers Daniel.
66brm ·
Daniel, the jets are identical right through the idf range, so if noone gives any joy here at least they are available stateside
Aka5000 ·
weber performance melbourne 0448609434
bits of italy melbourne 9794 6692
only problem is most places are now closed for christmas
alex
Arpspasm ·
Yeah thanks guys, I did find weber performance melbourne but my shopping cart price started climbing quickly so I thought I would check for some second hand ones first. You never know your luck!
Sides ·
Most any carb place will have the bits you're after... but yeah, pricey.
Also means that used ones aren't much cheaper than new... it's not like jets will wear out after all.
If you're not in a hurry I reckon try e-bay.
Arpspasm ·
Haha it looks like will just have to buy new ones then block all knowledge of the spending from my memory 🙅 like all the rest of the mounting expenses.
I am close and can help, just not sure with emulsions, may be able to rob some from a set to be replaced if your desperate. Give me a call.
ps 45's seem a bit small tho
matberry wrote:ps 45's seem a bit small tho
I use to run IDF36's
Everyone told me to run 50's
Had rich backfire
I went against advice and ran 45's and was sweet.
Best lean on mixtures was about 1.5 - 2 turns out
Interesting that Jon Connolly upgraded is Jetting Basics about a year ago.
All Jon's words refer to Webers
"for IDFs, make the idle jet 1.25 the size of the throttle body. For example, a 40 IDF would need a 40 x 1.25 = 50 idle jet. A 44 IDF would need a 55 idle jet, and a 48 IDF would need a 60 idle jet"
So.............36 x 1.25 = 45
Have a read here
http://www.aircooled.net/gnrlsite/resource/articles/jetting.htm
Cool, thanks
Arpspasm ·
Thanks heaps Mat I will give you a call after the chrissy madness is out of the way. Maybe I could drop the webers in when I get down to pick up that head you bead blasted for me? I might end up needing to bring my "slap together engine" down as well to make sure it doesn't fly apart on ignition :P
No worries Dan. We'll be away enjoying the rain in the kombi untill the new year, merry Christmas. 🙂
Gracey ·
Had rich backfire
Have a read here
Good info, however every combo is different.
For example take my stock 1600 Bug. It's completely stock except for a set of extractors.
I fitted a set of 36idf's that came with 47 idle jets.
It was an absolute pig to drive and my wideband showed lean, I ended up with 52's and now it drives great and gets good economy.
I'm not saying John Connolly is wrong, just that every combo is different and needs to be treated as such.
Gracey
I couldnt agree more
I keep telling everyone you engine needs what it needs
Learn to jet
Arpspasm ·
matberry wrote:No worries Dan. We'll be away enjoying the rain in the kombi untill the new year, merry Christmas. 🙂
Merry christmas to you as well. Watch out for those other crazy drivers on the road 😂
