volts..........Ah
https://forums.aussieveedubbers.com/threads/87785/voltsah
donn ·
Voltage: 7.4v
Capacity: 1500mAh.
Voltage: 3.7v
Capacity: 1700mAh
Two different camera baterys, can someone explain why more volts = less Ah.........i would assume that all batteries work the same ie. car batery.... could it be the size of the cell used to make the unit?
waveman1500 ·
Because producing more volts requires more cells, each of which must hence be smaller. It depends on the specs of the individual battery though, it would probably be possible to specify the higher voltage battery with even more Ah than the lower voltage one if the manufacturer wanted to. Also, all batteries do not really work the same, the basic concept is the same but the materials and construction vary wildly.
donn wrote:Voltage: 7.4v
Capacity: 1500mAh.
Voltage: 3.7v
Capacity: 1700mAh
more cells = more voltage
larger cells or different materials = more mAh..
rechargeable AA batteries [really a cell] can be bought in various sizes of mAh... 2450 2500 2650 2800 and ones in solar garden lights are 800 mAh.. all at 1.25 Volts DC
naturally the more charge capacity the longer they last...
a cheap AA battery won't last long at all...
Alkaline are much better..
then there are Energiser Lithium etc which last a along time but can cost up to $7 each...
I bought some rechargeable AA batteries and a charger when I bought My camera... now I use rechargeables in everything... lol
AA & AAA ... so leaving a torch etc on doesn't cost Me money..
