Down Under Beams Available at VVDS
https://forums.aussieveedubbers.com/threads/87811/down-under-beams-available-at-vvds
captainvw ·
Up to 4.5'' narrowed with shock towers ,up to 8'' narrowed without!
These are the best Beams on the market !
Laser cut uprights
Two piece Tin KDF (Bugboy) designed shocktowers
Perfect fit
each beam fitted with a DUB (Down Under Beams) plaque
4.5'' beam ready for install
Fitted
6.5'' beam
All beam are Tig welded by a ticketed Boiler maker with 10 plus years experience .Every beam is welded in a Jig and let cool before removal for as little distortion as possible (less than stock)
These Beams are not engineered as they are narrowed
Down Under Beams PRICE LIST
Bare steel beam with shock towers $625
Bare steel beam with out shock towers $575
Bugpack Bushes (No machining needed) $75
Quicksteers $65 (recommended for anything narrower than 4.5'')
Painted add $30
Spring Packs shortened and Redimpled $90 per pair (using your springs)
Tie Rods cut and re tapped $60 per pair (using your tie rods)
Stickers $ 5 or buy a beam and get one free
Beams can be sent via Australia Post Registered and insured for replacement value for $50 interstate
Down Under Beams does NOT narrow O.G. beams ,and does not sell shock towers etc separately
Lindsay Brown 0409493012
Gosford NSW 2250
DieSchnelleKafer ·
woa 🤪
sick beams dude! say, how close does the 4.5 beam get to the body at the top of the shock tower?
NUG637 ·
will this lower my beetle?
captainvw ·
NUG637 wrote:will this lower my beetle?
SMB's
DieSchnelleKafer wrote:woa 🤪
About a bee's Dick 👍
NUG637 ·
😂😂 seriously tho, well built beam 👍
Wannavee ·
cock
Thatbrickhurts ·
Great quality.
Hey I was checking those US beams out of interest. The guy selling them sounds like a really honest seller...NOT
Check his feedback here
http://www.thesamba.com/vw/forum/viewtopic.php?t=261369&postdays=0&postorder=asc&highlight=unrestoredcarz+sbcglobal&start=0
h ·
😵‍💫 haha some funny shite 🙂 made me laff
fish26 ·
Each to their own fellas, but you all sound like high school kids slagging other people and their product, I have dealt with Andy, the seller from US and not had a problem.
I've not seen a DUB beam in the flesh but it looks the nuts in photos, well done Cap'n.
I have used the shock towers though, top notch.
jhp1 ·
I have bought about 8 of these beams and they are without question the best modified/narrowed beams I've installed
Unfortunately when you do things properly they cost a little more
But like most things in life you get what you pay for 😉
captainvw ·
LUFTMEISTER wrote:They are both non engineered products and should have a warning as such " for off road use only" The US product is a very good price, but if the local product is well priced and made, it should sell itself, like all good products. Maybe the local product could explain the $200-300 price difference to help buyers decide?
Luftmiester would like to justify the cost which is a fair question.
The steel costs alone for me to buy for one 4.5'' beam is $275 dollars .That is for the Laser cut steel and tubing .Obviously the price would come down if i was making large batches which i'm not
The shock towers i use allow you to go narrower than 4'' without body mods and are 10mm thick not 1/4'' .They are made this way to copy the 10mm boss on a standard beam .These are 2 piece design and are more labour intensive than a 1 piece obviously,and cost more to get made.
Then we have the 3 piece uprights. The bosses alone take 20min (for 2 body mnt Boss's) to make then they are placed in a jig and the 3 piece upright is welded together
We then have the beam tubing.I don't have any fancy tooling in shop so the tube is measured and marked i then drill 2 holes in the beam and slice the slot for the adj with a 1 mm cutting disc the adjuster is then tacked on and the hole cleaned up with a die grinder if needed
This process is slow in itself but all i can do.
The beams are then placed in a Jig that holds the beam during the welding process .I then tac these together using a Mig .These are then taken to my friends shop and are TIG welded (he has over 10 years experience and has is various tickets etc)
While not forgetting the Adjusters and Bushes need to be bought from the states and postage is half what the parts cost me
All up there is easily 4 hours in each beam MINIMUM then the transporting of them to and from shops etc
Im sure i could come up with a more cost affective designed beam but i wont because i know i wont be happy with it.
I think the quality of these beams speak for themselves,at the end of the day i don't need to build these i choose to.The less time i spend building beams for other people the more time i have for working on my own Dubs 👍
HappyDaze ·
A bit over 30 years ago, when my boys wanted to go BMX racing, I made a rack to fit onto the tow-bar to carry the bikes. Soon 'everyone' wanted one, so we started making them. We called it MAC-RAC, and ended up making thousands of the damned things.😏 Sold out about 25 years ago. There were MANY inferior copies.
I know how difficult it can be when customers say that they can buy a cheaper version of your product. Some people will buy the cheapest, no matter how much better your one is. However, I find that - in general - most will consider all the options, and not allow price to be the only consideration.
The important thing in NOT to cut back on quality for the sake of making a cheaper product. Not everyone can make a quality product. My son Tim (then about 12 YO) came up with the slogan, "Don't buy a slack rack, buy a MAC-RAC". Emphasize the quality.👍
Cheers, Greg
LUFTMEISTER ·
Thanks for the sane response. The quality of your beams is self evident and the avis adjusters are more expensive and give better clearance to low riders that the bolt type. Now it is up to the punters to decide. Cheers
Peter O ·
Capt
Do you do wide beams say 6 " wider than stock with a longer shock tower?
captainvw ·
Peter O wrote:Capt
Anything is possible what is it for?
Peter O ·
captainvw wrote:
Peter O wrote:Capt
It would be for an off road buggy. I have built a few before but it doesn't hurt to ask as it is a very time consuming job to do it right. I have had trouble accessing the tubing to build another so thought I would ask.
I have also looked at bringing in a set of tubes from the states with longer leaf packs to suit and will most likely go this way.
Thanks for the response
captainvw ·
Hey Peter o would love to see a pic of these things if you one...
If ever you want tom make one let me know can hook you up with the Tubing and uprights ,the Shock endplates can be bought from Bugboy.
Peter O ·
captainvw wrote:Hey Peter o would love to see a pic of these things if you one...
Thanks Captain I might take you up on the offer of tubing source.
I don't have pics I can show but if you made your beam 6 or 8 inches wider than stock and lengthened the towers to accept long travel shocks and added a triangle brace back to the tube on the inside of the shock tower and a bump stop and brace arrangement above the top swing arm with your uprights as braces in the centre and at the outer ends you would have a strong tube suitable for long travel off road use.
Tubes bend when you land on one wheel or hit big bumps hard so we brace them back to the chassis right out at the ends as well as the mounts that would attach to your centre uprights.
Do you have to hone the tube to get the bushes to fit
or are you able to get correct inside diam Cro Molly tubing?
captainvw ·
Was wondering if you braced them i could imagine them turning into a banana after a big hit
The tubing i use has a seam sits maybe 2mm proud, I skim a 5mm flat (across) on the bushes so they push in with a little force by hand.Im not sure on the moly tubing never really looked into it.
HappyDaze ·
Errol Richardson from Canberra makes a chromoly beam. They are a work of art.
Mr Bubble Head ·
I've put one of these 4.5 inch DUB beams in a 59 and was overly happy with the quality and the ease at which everything went together. My tip for the bushes is to get one of those thin (1.5mm I think) grinder wheels and score a 2mm groove in each bush this is to compensate for the tube weld/flash joint. or do as Captin says grind a 5mm flat, either way same same result.
chequer57 ·
HappyDaze wrote:Errol Richardson from Canberra makes a chromoly beam. They are a work of art.
This beam built by Erol was as a proposed alternative to the Ball Joint Beams used in current Formula Vee.
The D.U.B. looks good it I ever got a road going Type 1 I'd put it under there and get the OEM Beam speced for a Historic Vee 😉
bnicho ·
HappyDaze wrote:A bit over 30 years ago, when my boys wanted to go BMX racing, I made a rack to fit onto the tow-bar to carry the bikes. Soon 'everyone' wanted one, so we started making them. We called it MAC-RAC, and ended up making thousands of the damned things.😏 Sold out about 25 years ago. There were MANY inferior copies.
I've still got a bright yellow MAC RAC. My parents bought it in 1983 or 84. I use it for my son's bike still.
PASHN8 ·
Great product and great service from the DUB team, mine is on order! 👍
LIFE IN THE LOW LANE ·
Is there a possibility of doing Type 2 beams for Split and bays??? Sure there is a market for them as well.
Great looking product too!!
captainvw ·
LIFE IN THE LOW LANE wrote:Is there a possibility of doing Type 2 beams for Split and bays??? Sure there is a market for them as well.
Would love to offer bus and type1/into type 3 conversion beams ,with real work commitments i just don't have the time to expand at the moment .I have the PDF files for the end plates so it is definitely on the cards when work slows down
captainvw ·
Nice looking clean beam, those end plates look the goods .
humpty ·
Hey Cap.... If you need the dwg files to build a TIII conversion beam, I can hook you up.... I've built a few in the past couple of years.... Not a lot different to what you have really.... Just different framehead mounts.... Let me know brother.
captainvw ·
humpty ·
Oooo, pretty!
kroozzn63 ·
gotta love a line up.. nice one LJ
hellbugged ·
how low are the adjusters set up?
would i still be able to get or near to a standard height?
thanx
captainvw ·
hellbugged wrote:how low are the adjusters set up?
thanx
Sure do, unless someone wants to go real low without spindles i can rotate them around some more.All my beams are built to order.
sander288 ·
This might be an out there type of question; but could a beam be designed to run ball joint trailing arms etc, but bolt up to a link pin frame head?
If they are built to order would it be possible?
Shaun
hellbugged ·
are they extended shock towers?
And you do 2 inch narrowed i imagine?
How am i ever going to keep this stocker unmolested with gear like this available!
sander288 ·
it's like a biggest loser temptation for you daimo! 😂
humpty ·
sander288 wrote:This might be an out there type of question; but could a beam be designed to run ball joint trailing arms etc, but bolt up to a link pin frame head?
Shaun
No... The torsion tubes are of a different spacing.
captainvw ·
hellbugged wrote:are they extended shock towers?
Shock Towers are extended to allow standard shocks when lowered 2'' narrowed is possible
captainvw ·
Down Under Beam's 4.5'' narrowed Link Pin beams are now available at VVDS and Raw Auto werks
when 2'' isn't enough 👍
Wannavee ·
You'd know all about that! 😂
Ryno17 ·
Just want to say DUB beams are the GO! Bought one off Lyndsay. Fitted the next weekend and fitted perfect. Second to non for quality. Would recomend to anyone who only wants the best and wants a slamed and narrowed VW in OZ. Pics soon to come on my little project up here in Coffs Harbour. Thanks again LJ
captainvw ·
No probs Ryan cant wait to see the build pics 👍
captainvw ·
Here's a 6'' Link pin were the customer wanted to run a top trailing arm on the bottom tube as well to keep it neat and tidy.
So we built the off set into the beam 😎
DieSchnelleKafer ·
hi there, merry Christmas
are you still selling these beams, and who would i contact to get one.
thanks for that
-Blair
surfpig ·
the man above you should sort you out.
captainvw ·
4'' Beams now available for the Price concious buyer !
Tig welded (Not Migged)
4 inchers now available 8)
humpty ·
Nice work LJ.... Good to see the product range expanding little by little...
captainvw ·
These will double as Type end plates 😉
Pollywaffle ·
I forgot to post in this thread, but a couple of months ago I bought a 4.5" DUB beam. This workmanship and quality of these beams are second to none. If you're tossing up whether to get one of these...go for it. You won't be dissapointed. My mechanic said it was a pleasure to work with as the fit was spot on.
One very happy and narrowed customer here 😀
bitemeoz ·
How much are they?
captainvw ·
Looking at $600 for the 4 '' these are for a Type 1 Link Pin beetle type .If you are located in Sydney you can see them for yourself at VVDS .
captainvw ·
Thanks Pollywaffle makes the hours spent in the shed worthwhile to here happy customers 👍
Allbones ·
Bump, are these still manufactured?
hellbugged ·
yes they are
hus22l ·
These look fantastic! Super keen to get one ... Will get my blue slip first though... Please don't stop making them
In te next 6months!!!!
lowvwbug67 ·
They are really good. This is my 4 inch narrow beam i got off lindsey 3 weeks ago. Top work
oildrippa64 ·
Have seen these in pre-production, Lindsay does awesome work. Will be ordering mine shortly.
captainvw ·
Still building them as time permits will be doing another run in the next month if your anyone is keen just shoot me a pm
baywindowbandit ·
Are you thinking about doing type 2 beams as well? as I'd be interested in one for my low light.
whatnowthistime ·
Cheers, Greg
a bit off topic from the little man's beams, but I was sorting out stuff at my parents place and found our "mac rac", complete with stickers so I know it's a real one, still looking perfectly serviceable after 25+ years. a nice bit 'o kit you made there greg.
oldturtle22 ·
G'day, are these beams still being manufactured?
LukasForeals ·
hey guys, are these still available?
paulr ·
Try this bloke
http://skinnedknuckles.com.au
