After a 6v auto choke for me 28 PICT carb. Anyone got one? That works too 馃檪
Mike
Lawnton
QLD 4501
0734674488
chequer57 路
Hi,
I have one
You can have it for free + postage but how do I check that it works for you ?
Regards,
Ian
bushed 路
maybe a lantern battery 9vlt
should do no harm
its the setting in the car that matters
dekkerboy 路
I got 3 whole 6v carb setups if your interested.
psimitar 路
Cheers guys.
Nowt wrong with the carb I have. It's all been cleaned and has not slack in the throttle spindle just has no auto choke.
Chequer57 - to check you connect a battery and hold the accelerator arm fully open so that the choke plate should be closed by the autochoke and then as the bi-metal coil in the choke heats up from the voltage connected to it the choke plate will slowly open 馃槈
let me know who wants to sell me one as I'm in need 馃檪
Mike
chequer57 路
Cheer I'll give that a go tomorrow and let you know. The carbie I have is in bits so it's no drama I'm a 28 PCI man personally ....
They are what you use on the older Formula Vees.
psimitar 路
Cool. Let me know dude otherwise I know someone in UK for a NOS one.
chequer57 路
Hi,
I hooked it up last night, choke mechanism got hot but the choke butterfly stayed put. Sorry I could not be of help.
Regards,
Ian
psimitar 路
cheers for trying dude. BTW, did you check the plate moved freely before you tried? the Bi-metal strip aint that strong and getting warm is what it's supposed to do 馃槈
chequer57 路
Yep nothing happened .... if you still want it I'll mail it to you with the bottom half of the carb too, you may be able to sort it out.
psimitar 路
Hmm, just the choke element is needed really and will keep postage down if it is buggered 馃檪
May aswell give it a go before spend $40 on a NOS one 馃檪
bushed 路
is your ceramic section intact???
this is where the elemnt is slotted into
psimitar 路
The connector has busted lose from the ceramic and I've electrically tested and I get no ohms reading or continuity plus when powered up she do nothing captain 馃ゲ
bushed 路
stuck in floods or i would find u one
psimitar 路
I here ya dude. I'm on some high ground surrounded nearly 馃槈
