dangerous wrote:There should be no axial play in the flanges.
There may be some play in the splines of the flange though.
The bearings can be replaced with mostly normal shop tools,
except for a tool that can be home made to remove the bearing adjusters.
Get your self a good workshop manual if you want to tackle it your self.
Most likely there are other weaker links within the box,
that will fail before requiring a superdiff.
OK what workshop manual should I order most of the ones I have seen are incomplete or do not cover the 1975 australian transporter that makes up most of what I have.
There is no noise in the transaxle but I have play on one side so want to investigate before I kill it and should be able to manage the basics.
Wheere is the best place to order transporter parts from in Australia. I am country NSW so no local shops for me.
