Hi Guys
Engine is a 1994 EJ22
Had a problem with my thermostat and the engine got quite hot about 110 deg C at one point as i limped back home .
Have since added a oil pressure gauge and after fixing the thermostat .Oil pressure Ok on startup then fades away as it warms up.
The oil pressure is very low when engine has warmed up (5 mins ) and the oil pressure light also comes on
No engine noises and the oil presure light was working fine before the overheat
Will be changing the oil and filter tomorrow and checking the oil pressure relief valve
Any ideas on what to check after this
Cheers Gaz
gaz58t2 ·
