Aussieveedubbers · Country Buggies
Lowering spindles
https://forums.aussieveedubbers.com/threads/88192/lowering-spindles
bearwin ·
guys say my country buggy has the original front suspension, could i use the lowering spindles kp/lp used on early beetle?
or just put a front beam from a donor beetle?
i do have an extra pair of kp/lp lowering spindles, dont know if they will work on a country buggy
Smiley ·
You can probably run just normal beetle spindles. I think the only difference that you'd want to check out is the Link pins might be a different diameter from memory.
And if you want to sell your country buggy spindles dibs on them!! 😀
Smiley 😎
from memory a CB front end has Kombi axles ??? I think
vwjon ·
yep CB's have (origionally) splitty arms and link king pin spindles, so if you want it lowering, swap the arms etc for standard bug ones and it should go down a couple of inches (weird why suspension height and tyres are still measured in inches, just a thought!)
bevoracing ·
Jon is of course right. The trailing arms are same as Type 1 and will take beetle link pins. The whole type 1 king and link pin assembly will go straight on the arms. This will both lower and narrow the car significantly. You will also need Type 1 outer tie rod ends. The main beam is type 1 (and directly interchangeable) but the CB has some strengtheners around the bump stops.
Most people are trying to get the standard “high” front stubs for their CBs. If you have a set of stubs, and perhaps a beam, for sale they should be quite popular.
Have a look at:- http://forums.aussieveedubbers.com/viewtopic.php?tid=86968&page=1#pid811077
Tony
bearwin ·
ok thanks for the reply, i was just thinking to replace the whole cb beam to a type 1 beam assembly and add adjusters and drop spindles in the future...😎
