Hey guys, looking at changing the diff ratio in an 89 T3 van,
currently running 4.83:1
Would a 3.9 be too high?
pete wood ·
probably.
you want the 4:56 that was in the 091/2 litre box.
dogo ·
Not if you have enough HP to push it.
ahoogah ·
dogo wrote:Not if you have enough HP to push it.
Running a healthy stock ej22. Revs too high atm
rocknrob ·
just stick some bigger diameter tyres on the back👍
ahoogah ·
bigger tyres could work well, currently running std 185/14's
1st 12kmh (or slip start in 2nd)
2nd 25kmh
Would anyone have any larger wheels/tyres that I could borrow/try.
15"-16" 89T3.
Thanks,Dave.
rocknrob ·
Hi Dave, I'm in labrador you are welcome to try some of my 16's...40k in 1st 70 in 2nd only trouble is most non standard rims require longer studs...cheers Rob
ahoogah ·
Thanks Rob, what size tyres are you running on what type of wheel.
Cheers, Dave.
rocknrob ·
Hi Dave i currently have my country mouse tyres on...i went camping last weekend but for extended road use i run my city mouse tyres...both work out the same diameter...gives 105km/hr at 3000rpm
[/img]
[/img]
dirt tyres are 245/70/16 road tyres 255/65/16
perfect for a kombi with sooby motivation
rocknrob ·
the steelies are BA falcon 16x6.5 and the mags mercedes 16x7.5...both have ET around 36
ahoogah ·
rocknrob wrote:the steelies are BA falcon 16x6.5 and the mags mercedes 16x7.5...both have ET around 36
Thanks Rob, falcon rims should be easy to get,do they require longer studs.
They fill the wheel well nicely and will give me the revs I am after. What sort of speed sensor do you run.
Thanks again,Dave.
General_Failure ·
You drill the steelies or get them done somewhere? If you did it, how? and if someone else did it, what sort of cost?
