My little flowers 89 caravelle has a oil leak which is dotting the back window with oil spots, am thinking engine seal.What should i look for if i drop motor out.Any tips appreciated.
silver ·
New rings
rear main seal
clinker42 ·
What about a good degrease and clean and then see if you can spot the leak.
If you pull the notor then I would do a quick reco, hone the bores, polish the crank, new bearings and rings
put Nulon (or any other brand) "stop Leak" in the oil................works a treat 😉
greedy53 ·
is it auto when i had one the auto was leaking and it covered the back window with oil took a bit of head scratchng before it was solved
Oil leaks on a T3....I'd be checking one of the oil pressure senders for the source. Degrease and have a very close look to see exactly where its coming from.
zedman ·
Thanks for the help fella's.degreasing today then sorting problem from there.One more query though, how difficult and costly to replace rear brakes with discs? Cheers.
