WSID wed 2-2-11
https://forums.aussieveedubbers.com/threads/88469/wsid-wed-2-2-11
RodPenrose ·
I will be at Western Sydney dragway tomorrow night with my circut car testing a new engine . I have assembled a 2443cc engine specifically for the Portland weekend in a couple of weeks time and will give it a run to see how it will go . This engine is based on an original ARPM case , 88mm flanged crank , 5.7" Carrillo rods , JE pistons , AA long barrels , Fk 87 cam with Autocraft 1.4 rockers , Autocraft Pro heads with 48 x 38 titanium valves and 14.27 compression . I have a set of 48mm IDA carbs with 42mm venturies , 180 mains , 205 airs and 60 idle jets . I have a Scat 1 3/4" ceramic header with a fatboy muffler for the street meet only because of noise restrictions . This engine was dyno'd last week with 198 HP and 311 ft/lb's at the wheels . I will try to put the car on the scales , but should be around 1900 lb's with me . I will try to up-date at the track if time allows , ROD.
richie webb ·
Hi Rod
good luck with it,I am interested to see how that combo works out,
still minus 1-2 degress c here so no racing for a while yet
cheers richie,uk
ian.mezz ·
Howd you go ???
RodPenrose ·
Ritchie , good to see you are freezing while we are sweating . Ian , all went well sort of .
I had a good night at WSID and with the high temps in Sydney the track was very sticky . The first run was just a shakedown to run the car , and with 20 psi in the tyres , 6000 rpm on the 2 step , 1.62 60ft , 8.0 @ 89.22 1/2 track and 12.42 @ 110.31 at the end with a missed shift into 2nd .
All good so 2nd run with 18 psi in the tyres , 6000 rpm on the 2 step , 1.67 60ft , 7.59 @ 91.82 1/2 track and 11.92 @ 112.46 .
On the 3rd run I lowered the tyres again to 16 psi , 6000 rpm on the 2 step , 1.68 60ft , 7.56 @ 92.59 1/2 track and 11.87 @ 112.68 .
4th run I left the tyres @ 16 psi , and lifted the 2 step to 7000 on the launch to try to stop the car from bogging on the line , 1.65 60 ft , 7.88 @ 88.62 1/2 track and 12.28 @ 111.17 with a missed shift into 2nd again .
5th and last run I left the tyres @ 16 psi , lifted the 2 step to 7500 rpm and with no burnout , launched the car to have it drive all over the lane for about the first 60 feet . I drove it slowly back to the pits and I suspect I have either broken the welded diff or perhaps a CV joint . I am happy with the outcome and will now remove the box for an inspection and possible replace the diff with a new aluminium spool . The car weighed in @ 715 kg or 1820 lb/s with the driver on the startline and I have fitted some 8" hoosier slicks . I have a 3.1 first gear with the 3.88 R&P and I dont quite have the power to make the car launch well . I am looking forward to the Portland Weekend in 2 weeks time , ROD.
20bkombi ·
Hi Rod, well done mate, 92.59mph 1/8 with more in it with a better 60ft to offer. On top of that spool and slicks.😏
Looks like your in for some fun at portland!!!😀
Aaron.
STOCK ·
sounds good rod pretty descent no.s for first time out
with more to come with improvements
top work
see ya @ portland
