Guys
Do Beetke 1300/1600 engines have two different size main bearings.
I just recieved my new crank and went to dummy up the short and the main bearings have a smaller external diameter than the case. So for example, when you stick in the rear main/thrust bearing, it is really loose in the case and it can slide backwards and forwards in the case as well. By about 1 mm.
On the packet it has HL 87 978 600 std Suit VW 1300, 1500, 1600, 1700 A AR.
Does anyone know whats going on.
Thanks Trev
clinker42 ·
