I'm converting my '67 beetle to 12V, and when I've mounted the fan on the genny shaft there is a rub between the back of the fan and the backing plate.
The fan is mounted onto the hub with no washers/spacers at back. At the front there is a washer and lock nut. The 'washer' is a special with the cut-out to suit the drive shaft.
My question is, should there be spacers between the hub and the shaft to shift the fan axially out along the shaft and thus clear the backing plate. My feeling is it's more likely my backing plate is a little warped but just wanted to check before I start any panelbeating on it - I've only got one!
Thanks, Angus
karmann54 ·
