I am buying a 1970 lowlight kombi that's got front disc brakes and rear drums from a 1971 (small 5 bolt pattern).
I want to fit the original wide 5 steely's back on but retain the later model brakes.
Is there an adapter plate i can bolt on to do this?
Thank you.
barls ·
they are available but arent road legal. better off to get new drums drill to the right patten you want.
rossdanialnaumov ·
And re-drill the front discs as well?
Thank you.
barls ·
id go new over redrilled as the stock discs and drums dont have the thicker material needed where you will be drilling.
Special Air Service ·
I dont think it will be possible to re-drill your existing set-up to suit wide 5 stud pattern, there wont be emough material to fit the wide 5 stud pattern 5 x 205mm.
You'll have to change your brake set-up completely or go down the path of adapters, which has legality issues as previously stated.
Brendan
rossdanialnaumov ·
Ok, thank you guys. I'll do some further research into new brake sets and make a decision from there. It's a shame to buy new brake sets when someone has gone to the trouble of fitting later model discs.
