Beetle stuff for sale
https://forums.aussieveedubbers.com/threads/88577/beetle-stuff-for-sale
tdegens ·
Early Fuel tank with reserve tap $70. Chromed Generator which has the inside coil loose chrome is ok $60. Beetle Motor - F number - that was line bored by Garry Moody. The case was cleaned and checked and the crank measured and the bearings supplied by north coast engines The top end was ok with good power and no oil burning. The heads were good. $200.
Metho cooka $40 should work never used it. Looks simple enough gravity feed metho. Water Pump Homda 5.5 hp $60 goes. Also a fasty tank $40. I also have a 73 Fasty with a working complete motor in place. Good gearbox. Doors, seats, dash gone $500. I can email picies pickies wont load being 124k
Pick up or post with fastway
Tom Degens emerald beach NSW 2456 0266562864 0458562865 tdegens@gmail.com
baghall ·
What type of gearbox is it?
pickstock ·
is the engine running? what does F engine detail (single port, size etc)
does anyone else know shipping to SA??
tdegens ·
The motor is crankcase assembled and pcband head sitting in place. Th etinware and exhaust etc needed. New bearings good crank, linebored case.
The gearbox is 1973 standard fasty.
Calcool ·
Can you post some pics of the engine.
I am a bit confused, was it recod and the piston and barrels not fitted up yet, nor the heads?
How long since it was assemled? does it have its flywheel and has this been fitted and end play set?
Are you coming to Brisbane anytime soon?
David
0434 58 22 64
tdegens ·
the flywheel is not on, the
pistons barrels and heads are on but not tight. no tinware just bottom end assembled with new bearings and linr bored. cost me $300 so out it goes for $200
hellbugged ·
so fasty motor is running and complete?
what state of health is it in?
