Anyone fitted rear seatbelts in a T25 Trakka
https://forums.aussieveedubbers.com/threads/88594/anyone-fitted-rear-seatbelts-in-a-t25-trakka
NZVWNUT ·
Hi - has anyone had success with fitting 3 point seatbelts into a 1982 ish trakka? I have just bought one and am keen for ideas on the best way to fit these. Thanks
use the origional mount points they will be ther u may have to poke around to find them
grumble ·
I have a rear seat and a set of inertia belts and associated mounting brackets if you are interested,these came out of a later model but I would assume that the points are the same.Cheers
Kombi Dad ·
I have rear seat belts in my '82 camper. One is a lap sash. The other two are lap. The lap sash uses the original mounts as does the centre lap. Drivers side lap uses an original mount and a new mount as the cupboard is in the way to use the original lap sash mounts. I had to get an engineer's certificate when registering it in NSW (was originally registered in ACT) as the compliance plate said seating 2. It now legally can carry 5.
