i have known for quite some time that the mirrors on my bus are not standard, they screw on with 2 small screws rather then twist on like the proper ones, and they are big, black and plastic. when i removed them to check rust the other day however, i found that the hole for the original did not exist, i could not see any bogging or repair work, the threaded hole just seemed not to exist. did the panel busses come without mirrors and mounting points?
koolkarmakombi ·
I have the 'normal' holes in the 'normal' places. Normal mirrors too! :P
oh, Normal panel bay
:thumb
KruizinKombi ·
As far as I'm aware, they all had the screw-in mounts in the doors - even the panelvans.
It could be that someone has just done a good job of concealing the holes, or perhaps they even welded a panel over where the hole used to be.
baybuscamperkid ·
I will have to get a torch in there and report back, but i couldnt even see the threaded nut at the back, just seems an odd waste of time, to conceal so well.
