engine won\'t start
https://forums.aussieveedubbers.com/threads/8873/engine-wont-start
OvalMat56 ·
Had my 36hp motor running the other week went to start it 2days won't start, but it still has spark and fuel. is there anything else worth checking??
Grey 57 ·
does it fire at all. Sputter and die or just no life at all?
If it definitly has spark then tip a bit of fresh fuel down the carbie. It will fire up then. If it dies soon after, say 30seconds or so, then its probably a fuel delivery problem.
If it still does not fire then its an ignition problem. Could be weak spark from a crook coil or bad condenser.
Best to check the points gap, and reset the timing and see what that does.
